30 watt charger?
reaperman
minnesota
I know dji recommends the max charging output at 29 watts. I'd like to have a second charger so I can charge with the included 3 battery charger I already have. Plus the ability to charge another battery inside the drone at the same time. I see Anker has a 30 watt charger, fast charger on sale today. Is one extra watt of power going to really make a difference, and is there a possibility of generating too much heat inside the drone using a charger like this? https://www.amazon.com/dp/B07R3S7P5...scsubtag=2b55bd72778611eba685c2ead178cde80INT
I use a 30W PD Anker charger at home. It has USB C for the PD output and a USB A output @ 5V 2A.
The PD output is negotiated via the PD standard and not a concern as to the 29W "limitation" DJI implies. So I connect the PD to the DJI 3 battery charger and the USB A to the Mini 2 or the remote. The Mini 2 will get warm in most cases no matter what charging method used directly, even with the 18W charger DJI supplies.
Tarun
