wardtom084
Will landing higher than the take off point zero out your altitude only to start out at zero feet again. I would have to say the drone would need to be shut off.
Not sure about the Mavic 2 pro, but I suspect it's like my Mavic Mini, which I know resets its altitude to zero the instant it touches down. I take off in my back yard and land on my roof, about 20 feet above, and the drone follows the rule, "When the gear touches the ground, you are, by definition, exactly 0' AGL". The altimeter resets and the motors turn off. I can then take off and come back down to the backyard, where the ground is now at a negative altitude, according to the altimeter. Of course, landing once again resets altimeter to zero.Will landing higher than the take off point zero out your altitude only to start out at zero feet again. I would have to say the drone would need to be shut off.
He could fly as he's wanting to whether or not he flies under Part 107 rules.Since your question is asking "is there a way"..............the answer is yes. As has already been mentioned, you can do it under Part 107 rules. Not necessarily the way you might want to do it, but a way none the less.
