I just bought a Mavic Pro after having a less than happy experience with a Parrot Anafi. As I am new to the hobby, I am taking some time to understand the in’s and outs of the Mavic Pro before flying it outside of beginner mode. It’s a neat machine.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
mavicpilots.com
Even in Virginia, there are a couple of Legal Things you may need to do…
You will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. I believe you Mavic Pro is required to be registered.
I registered my
Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
faadronezone.faa.gov
Since you live in Virginia, there are specific laws and rules for you to follow, please check to ensure these are current.
Drones are allowed in Virginia for recreational and commercial use, subject to FAA and local regulations. Read on for details.
drone-laws.com
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Pro, including the User Manual.
Learn and download Mavic Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy, Safe and Legal Droning…
