This isn't a flyaway per se, but I could easily see how it could be so I am adding this thread here. My A2S / RC Pro is acting odd. When the switch is in "N" (center position) the left stick works fine. But the right stick doesn't seem to be behaving correctly. When I pull the stick back (to move in reverse) the drone ascends and moves backwards or forwards. When I push the stick forward (to move forwards) it also climbs. Doesn't seem to happen in C or S, just Normal. I downloaded a log and posted it here:
One thing I notice is the flight mode shows P-GPS (Bypass). I checked and the obstacle avoidance shows "Brake" on the controller. Did I mess up a setting somewhere that's causing this? Or is something maybe defective? If so would it be the controller or the aircraft? I have my old RC-N1 controller around here somewhere but can't seem to find it at the moment to test it out.
Any other suggestions?
Thanks!
Jon
Thanks!
Jon
