Abnormal gimbal vibration in flight and on ground
pilotman24
florida
I am getting an abnormal vibration error on the app both on the ground and in air. I have checked the gimbal and it is inserted correctly and has not been crashed or hard landed. Any ideas? Thanks guys
Have you added any filters to the camera ?
First welcome, wonderful craft you have bought. I have the MP1, still amazed by it's tech.
Have you recently change props? Check to see if they are properly attached, check for damage and if you have a spare set, change them out to see if that solves the issue. Some had issues using aftermarket props (even the high quality ones like the Master Screws) with gimbal vibrations.
There are tiny black rubber bands that hold/dampen the gimbal, check those also. Good luck.
Noticed the title states it occurs on the ground also. Is this without the props spinning? If it's without you may need a new ribbon cable.
Here is an older thread where Fox posted some helpful videos.
sscott062
