"Abnormal Gimbal Vibration"
Hey all,
My mavic received a warning, "abnormal gimbal vibration", while flying this weekend. Can anyone help point me in a direction to fix this?
Thanks!
Usually you can fix it by buying a new one, or shelling out for an expensive repair. That’s the DJI way. Have fun.
Are you flying a Pro with Platinum props?
Hey all,
Thanks!
Got that same message once. Same symptoms. The Easy Fix: Examine the underside of the gimbal. 1. Make sure that all four "rubber bands" are connected at both top and bottom. 2. Make sure that the rear of the gimbal support frame is "hooked" under the black plastic L-bracket. Worked for me. Hope it works for you as well!
FIXED THE PROBLEM! Thanks very much my friend. Cheers.
Reactions: Hauptmann
iqbalNananannama
