Looking at my rc planes on a shelf made me wonder if anyone has used active track to follow a second drone or rc plane?
Yes, it is entirely possible. I've been doing it over the last several weeks to make a video. I've got about 30 fights so far, and no crashes! My experience is with an MPP and a M2P. The MPP is the subject drone and the M2P is doing the filming.Looking at my rc planes on a shelf made me wonder if anyone has used active track to follow a second drone or rc plane?
I tried it with @Made2Phly. It was not successful because we couldn’t accurately predict each other’s moves. I found a single pilot with a co-located controller mount and a calibrated view can result in better framing. Close proximity flying requires careful and precise control inputs.Surely if doing this / trying it, you will need a second drone pilot ?
It'd be a moderately difficult task to fly a drone or other aircraft and watch tracking effectively on a second drone.
Here is an audition draft of the video I’m working on. Lots of changes are being made to it along with new flight episodes. Episode 1 was largely using Active Track. Episode 2 was with both drones autonomous, flying a concentric POI.
The whole purpose of this exercise is to provide contextual cut away shots to generate drama. It’s just a draft, but you get the idea.
Very ,very cool video too watch.Here’s an example. It was flown mostly manually. But since then I have refined my techniques (my previous post).
Thanks. In my first try at this, I did zoom in on some of the 4K shots. But my recent attempt is natural 4K. And that brings up my issues with the POI maneuver… a lot of the sequences are too far away for my liking. I should have reduced the altitude of the M2P to get closer. I was manually using the sticks to constantly adjust the speed of the M2 to keep up. I may reshoot that whole sequence to get closer, and maybe use a larger radius. Also, the sequence needs to be more varied.Nicely done, I know you must have been close together there as you have to be pretty close to a drone subject to make it worthwhile viewing.
Otherwise the drone in shot is too tiny in screen.
Or did you do a combination of close and also crop 4K to get it bigger in the video ?
