Hi all,
A few months ago I got a used Air for a specific project. It did the job, but the gimbal had been repaird at some point before and would sometimes get stuck and not keep completely horizontal.
I got a replacement gimbal from aliexpress (just the case/motors) and swapped it. After jiggling the wires and connectors a bit, the camera works, and the gimbal turns on but is locked in extreme left (or maybe right?) position, and will get stuck at 10% when trying to calibrate.
Unfortunately the previous repair glued the big wire loom to the case in one place and I had to break off parts of the case to remove it. It looks like all the wires are intact, although the insulation is a bit torn in some places, so it's possible that something is damaged where I can't see it.
I tried to check the smaller flat ribbon cable, and it seems that one pin might not be connected through, although it's hard to say for certain testing it with a multimeter. It might even be by design if they have power and signal going through that cable. Does anyone know which cable does what? Any ideas what is the most likely cause of these symptoms? I'm trying to decide between:
Problem? gimbal doesn't calibrate after replacement
Was unit in a crash? probably
What have you tried so far?: restart, change batteries, refresh firmware, wiggle the cables
What device are you using? Galaxy Note9
What firmware are you running ( aircraft, remote controller)? newest
What Go app version are you using? newest version
Any modification? its all a stock unit
Did you change anything or install any apps? No
Do you have a video or pictures of the problem? See above, can make more if it'll help
- Buying one cable
- Buying both cables
- Buying the whole gimal again
