Air 2 really twitchy during auto-landing
Ice_2k
Romania
I usually use return to home to bring back the drone after I’m done shooting and then, while it’s descending, I use the sticks to correct it on top of the landing pad (precision landing has been a bit of a hit and miss for me but that’s a separate story). What I noticed is, that while in the auto landing procedure, in normal mode the drone is extremely nervous. The slightest touch on the right stick makes it jump as if I gave it full stick. Once I cancel auto landing I can easily guide it to the center of the landing pad.
Anybody else notice this? The Mavic Mini does not do that.
I would recalibrate IMU and compass ASAP to see if that resolves the problem.
I have not experienced any problem as you have described.
Reactions: Slade
if it would be a calibration issue, wouldn't it manifest itself at all times? Again, if I just hit the "Cancel landing button", everything works perfectly.
I don't necessarily disagree with your analysis, however, I think the general consensus (and my limited experience) seems to indicate that all Mavic aircraft typically exhibit rock-solid stability (unless there are very windy conditions) in this landing maneuver.
This leads me to conclude that this is a VERY individual situation and I would investigate my own personal equipment and setup.
deepdark
