Aloha from Maui
Thank you.
If you have a Facebook Presence, then you might also consider reaching out to the Hawaii Drone Pilot Group.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). If your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. Andif your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Hawaii, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Thanks. I flew an old drone for a few years. I am very experienced and about to get my
Thanks. I am not a new pilot. I flew an old drone for a few years. I am very experienced and was about to get my Part 107 license until the DJI proposed bans stopped me.
Reactions: LoudThunder
I have my Part 107 and I got it so I could fly where my Rec Pilot friends cannot fly. See the Map, I live in a very tightly controlled area and I ha e to call an air force base's ATC to fly in my back yard or get a LAANC Clearance to fly in my front yard…
Maui is not too tightly controlled but do not try to fly in Haleakala National Park… National parks are no fly zones…
The rights and privileges of a Part 107 are afforded to you whatever make or model drone you fly…
Reactions: wjkrysak and Cafguy
Welcome to the forum. We look forward to your participation and your view of the world.
seacoropeus
