Anxiously awaiting my Mini 4 Pro in Bailey, Colorado
DeaconB
Colorado
Sitting here in the mountain forest of Bailey, Colorado waiting for UPS to ring the doorbell with my new Mini 4 Pro.
1st time pilot with anything beyond drone toys (<$100), but a long-time pro-consumer photographer and tech geek. I'm really looking forward to adding a new tool to my photography toolkit.
Can't wait to dive into the community!
[Link Removed By Moderator]
Have you had any remote control experience flying a bird in the air?
String on it doesn't count. :rolleyes:
I was really good finding trees back then.
I'm much better now.
I can share some footage if you want. Thumbswayup
I almost most forgot..
Welcome to the FORUM !!
Rod ..
Glad to see another Coloradan. Lakewood is home for me.
Hi from Co. Cork, Ireland ☘️ ☘️
Get to know your new arrival , It'll seem like a minefield at first but take it real slow as the fellas on here told me to, don't try to take in too much in one go, I assure you it works !!! Your confidence will grow as you master each move or function.
Best of luck and safe flights
Murph
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Colorado, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum from up here in Estes Park! Happy and safe flying!
slus
