Any ideas on this?
mikeyoda
melbourne
00m 13s18.7 ft141 ftWarningBattery power restricted. Aircraft performance decreased to ensure flight safety. Return to home promptly (Code: 110013)
Any ideas on this error?
Here is the log of the flight.
Is it drone or battery?
Cheers
Mike
I see the flight started with a partially charged battery, 58%, how old was the charge?
When you start the flight with a battery that's been sitting around discharging, the % indicator doesn't give an accurate indication of the battery's true state of charge.
12 seconds into the flight, under the strain of climbing, the cell voltages were already hitting critical low voltage level (3.2 volts), too low to sustain extended flight and the drone cut the power drain to save your drone from crashing when the battery ran down prematurely.
The cell voltages should have been over 4 volts at that stage.
See details here:
And always start a flight with a freshly charged battery if you want to keep the drone.
Reactions: Yaros
Thanks, so the way I understand it, regardless of what the % says make sure you leave with full batteries. These were 2 weeks from last charge. Good information thanks for your reply and consideration.
Reactions: Meta4
Look the power page of AirData and then the Volt Amps tab. At the first message you were going to fast and using more than power than the battery could provide. From A to B on the amps chart you were drawing more than 15 amps. Fortunately the app forced a slowdown rather than battery failure.
Perhaps the battery has problems or needs to be charged more. In future just pay attention to not overload the batteries and check the battery condition on AirData after every flight.
The issue was explained properly in post #3.
Click the link there to see how low the voltages were.
All that's needed is to start with a freshly charged battery instead of one that's been discharging for two weeks.
Pro-MBS
