Environment: 500,000 Sq Ft Warehouse / 45' ceilings / Highest Point of Equipment in the Warehouse is 16' / There is no GPS Signal inside the warehouse
Operator: Skilled / Flying without GPS is not a problem
Drone: Early Mavic Mini 2
Problem #1 : Need drone to to exceed 16' indoors when no GPS Signal is obtainable. (Need to videograph the environment below from ~ 25-30' above)
Problem #2 : By taping up ground sensors on bottom of the drone, I can override the 5M no GPS Limit, however Drone goes into an un-flyable state after 1 or 2 minutes where descent can only be controlled by initiating the "landing sequence." It seems to work for a minute or two just fine and I have absolute control and then It goes nuts, losing descent capability and begins to steadily climb unwanted.
I also have access the drone firmware settings, however, I do not know which firmware parameter to tweak to increase the 5M No GPS Limit setting, remove completely, or to disable the vertical ground sensor altogether.
