Balanced battery cable install help
Texas Mavic
Can anyone show me where the best place to solder a balanced charging cable into the Mavic Pro battery pack on the “intelligent...” battery board? Any input and insight would be greatly appreciated!! I also have some battery mod questions if anyone is up to answering a couple. Thank you!!
Are you bypassing the batteries circuit board? What voltage pack are you going to use? How will you be able to charge the pack if the balance jack is soldered into the DJI battery board?
Reactions: Texas Mavic
Yes, that’s what I am wanting to do, the regular Mavic battery, I am going to put a balanced charging cable on a couple batteries. Right now I have a couple cheap chargers.. 1-6s looking to pick up a charger that tells me each cell voltage and discharge yada yada
A balanced charging cable into the terminal board looks like the way to go but idk, that’s why I want to clarify
Fordmanwon
