Baseline Max Height and Distance for Mavic Pro.
nutsnbolts
I'm curious as to what the max height and distance for the Maverick Pro should be set up as a Baseline. I know the rth is dependent on the area you are flying in but what do most people set their Max height and max distance despite where they are?
I turn off the "Enable Max Distance" setting to ensure the distance is not limited. For the RTH Altitude, I set it to the altitude of the highest obstacle in the flying area above the takeoff point plus an additional 50 feet (to make sure the Mavic definitely clears that obstacle).
If you are not a noob turn off the max distance and altitude and monitor it on your mobile devices
As msinger has said I also have this disabled and RTH hight is set based on my location each time I fly.
Curious why it's typical to set RTH pretty specifically with regard to obstacles in the area- why not set RTH to max altitude (400') to rule out a miscalculation I might make? (I'm sure there's a good reason :) )
What if the tallest obstacle is higher than 400 feet over top of the takeoff point?
Hint: You'll crash into it on the way home. That's why you should never use a magic number (like 400').
Another good reason is that your are forcing it to climb to 400' before it starts heading home whether it needs to or not. If you miscalculated or were pushing your flight time too long you might use up more battery than you have in that unnecessary climb.
Reactions: Drizz and Rokitt69
Stupid question if I see the drone and I initiated RTH and I realize it's about to hit something couldn't I stop the RTH sequence? Or even take control of the drone by moving the thumbsticks?
I noticed that when I'm landing I can actually adjust the drone as it goes down. Sorry I haven't really fully fooled around it enough to really know if that is the case.
As long as the remote controller is connected to your Mavic, you can press the RTH button on the remote controller to cancel RTH. Then, manually fly it back to the home point and land.
Thanks. So the remote is unresponsive unless you actually cancel the RTH. When it was landing I could move it. I'm assuming that is normal?
No. You don't want to take any chances though when your Mavic is heading toward an obstacle. After disabling the automated RTH flight mode, you'll be 100% in control of your aircraft.
explorjus
