I'll probably just buy some more batteries, but cmon, this is comical (until your camera falls out of the sky).
Contact DJI support. They've replaced 3 batteries quickly and painlessly.I'll probably just buy some more batteries, but cmon, this is comical (until your camera falls out of the sky).
Not yet. I'll see if I can get that info and post it.Any information on charge cycles and build date on this deformed power source?
Not worth the risk. Disposal would be the better idea.before I trust it fully
about 1 million drones that fell out of the sky since the mavic 2 was released.
haha, you got me. But I do think the swollen battery problem is VERY common, and I'd guess the number of catastrophes are much higher than dozens. No way really to know.Just a bit of an exaggeration, don't you think. Can anyone document even dozens of drones falling from the sky?
The actual polymer cell is not expanding - it is off-gassing. The cell pkg then bloats like a balloon. So, there isn't a risk of lithium polymer oozing out the hole. However, I'm not sure what the effect of introducing air into that pack is.Personally, I wouldn't fly with such a battery any more, especially after piercing the cells. The next time the polymers expand (for the same reasons they expanded before), it will squirt out of the bag and into the plastic. It's not the lack of venting that causes them to do this, but the reason for the expansion in the first place (DJI is not using top-shelf cells).
And you're trusting your drone up in the sky using these. A couple of new batteries would be a much lower expense than a new aircraft.
I admit that I don't know the science here. If you do and can assure us that this is a safe thing to do, it would probably be a good thing to say so. If not, you might say so and add the caveat that folks follow your example only at great risk.
Chris
I did that with a Mavic 1 battery that didn't swell but had a sudden low power warning and landing soon after takeoff. After climbing a fence and crossing a busy street I found my drone on the edge of a active soccer field where I had been able to direct it. It was still blinking away happily after probably ten minutes. I took it home, and it charged normally. I flew it in the back yard and all went perfectly. The next time I flew it it gave the same low power warning and landed and it continued to do the same every time after. It never swelled or seemed very warm but it had a bad cell and that was that.I'm going to do a full 20 minute flight test with it (just a few feet in the air) and assess afterwards.
If you are interested in going down the DIY rabbit hole: AliExpress search for HSABAT (manufacturer) will throw up a 4-cell pre-assembled replacement. I have used their lipo's and am confident that they are a reputable company. The replacement lipo's I've installed are functioning reliably.I don't suggest anyone else reproduce my experiment here (somewhat of a legal disclaimer I guess). Nonetheless, I'm going to go forward with it. If it falls out of the sky, I can deal with it. I don't ever fly over people, not really concerned. If I have any other findings that I think the community would like to hear, I'll post back.
