Batteries slightly swelling after flight...cause of concern?
Dude has literally hundreds of LiPo batteries over many years and had a single charger fail only once.
It can happen, but it is clearly more like a lightning strike than a common event.
It's all fun and games until you burn your own house down.
Charging a damaged battery doesn't guarantee it will catch fire, and a swollen battery won't always cut out midflight and send your drone crashing to the ground, or potentially onto people or property below. Still, neither scenario is desirable. Simply replacing the battery not only ensures peace of mind but also eliminates the hassle of constantly worrying about the situations a damaged battery can create.
What is the normal lifespan for such batteries?
The lifespan of drone batteries can vary significantly depending on the model, how well they've been cared for, and even their manufacturing date, as DJI occasionally updates its processes.
From my personal experience, Phantom 4, Mavic Pro, and Mavic Air batteries tend to fail more quickly than other DJI batteries.
As a 30 year fire investigator, discard. Don’t even bring them inside. Fire proof bag and bury in sand.
Well, that may be a little overkill 😉
The most important thing to do with a li-ion chemistry battery before discarding it is to fully deplete it. Like, won't delivery current even to a short (don't short it to empty it!!!!!).
The energy in a charged lipo is responsible for most of the explosion and fire risk. When fully depleted (to the point they've been undervolt damaged) you can hammer a nail through the pack without it blowing up or catching fire.
Still requires careful disposal because it's toxic waste.
I always sit my batteries on a flat surface after a flight to check for swelling. I have read of batteries swelling and popping out of the drone mid flight which always concerns me. ( can’t afford a new drone )
I had the swelling issue with my air 2s batteries and replaced them with Refurbished units from a Authorized DJI dealer . Over a year ago. The interesting part was I got a 2 year warrantee on the batteries . All is well so far.
I have always charged my camera batteries to 100% for storage, and assumed the Drone batteries would be the same.
My only comment is that DJI should include the proper charging and storage instruction in the included written information when buying a drone, or just the battery.
I only found the recommended charging and storage information on their website after searching You Tube and this Forum.
BTW you can discard bad batteries at Lowes or Home Depot.
Best Buy also recycles batteries. My local store has conveniently placed recycling bins right at the entrance.
Personal experience. I had a Mavic Pro that I flew for 7 years and was proud I never crashed it. I was noticing some swelling, but didn't retire them. Flying in a park close by and suddenly the drone dropped out of the sky. The swelling got bad enough that it forced the clips holding the battery in place to dislodge and separate from the drone. No power to the drone = no more flight and it dropped breaking into several pieces. I've replaced it with a Mini-4 Pro and noticed the battery now goes inside a compartment. The redesign may have been as a result of this issue. So for now on, if I sense swelling, I replace immediately.
As I don't have any other batteries, I may end up using them for a little while longer. How do I know when they are at the end of their lifespan? They don't swell or get warm when charging.
Stop using swollen batteries! When your drone bursts into flames midflight and crashes, now you’re out a drone when you should only have been out a battery.
I hope to discard them long before they get anywhere near that dangerous.
Marlin
