Battery charger connection
Uncle Pete
USA/MA
Do the different models of Dji drones all share the same battery charger connection?
No with perhaps the exception of the MM and Mini 2. I believe you can charge Mavic Mini batteries in a Mini 2 triple charger but not the reverse as the cross section of the Mini 2 batteries is incompatible with the opening in the MM charger, square peg in round hole thing.
And even if they are close enough to work there are often, if not always, voltage differences
@Uncle Pete unfortunately DJI chargers are as far as the drone battery is concerned model specific so the original Mavic pro and the Mavic pro platinum used the same batteries and connectors ,then the M2P and MP zoom same batteries and connectors ,but then the rest of the Mavic airs and the spark have different connectors ,and batteries
Franker
