by what percentage does the battery consumption increase by switching to sports mode?
Simply switching to sport mode will not increase battery consumption, in fact it might decrease it because the drone no longer requires the obstacle avoidance to be monitored.
I think what you are really asking is how does flying in sport mode at higher speeds affect battery drain. The answer is it depends on the RPM you are asking the motors to produce. The motors will spin at higher RPMs in sport mode, allowing you to go faster, and discharge the battery faster.
You can easily do the test for yourself.
Fully charge 2 batteries if you have them, or fully charge one, then after the first test, recharge to 100%.
First fly in P mode full throttle in big patterns and set a stopwatch when you start. See how long it took to get to 50%. Land. Recharge or put in a new battery and repeat the test in sport mode.
Battery consumption should increase in sport mode, causing you to have a shorter flight time.
Thanks, my questions stems from this:
I have a shipwreck sitting about 3 to 4 miles from my house. I have a straight view from my porch to the wreck. If I want to take a flight to the wreck, am I better off going there in Sports mode full throttle or take my time in P mode full throttle. Which will give me more time to explore the wreck and come back safely?
I think the best way to do this is get in a boat. Get within LOS, and then launch from there. Any other way would be impossible. Not joking.
I did some math. Calculations are with no head wind, nap of the earth flying, no climbout time, no time spent at the wreck, Mavic in P mode, using conservative calculations.
22mph. Distance 4 miles. Time to distance = 12 minutes x 2 = 24 minutes. You're out of gas and in the drink about 1.5 miles from home. Then you will need a boat and scuba gear.
Dont forget about my boat suggestion.
BTW, before I would ever try this, I would have State Farm or other "total loss" drone insurance. If you did go down in the water and couldnt find your drone, and all you had was DJI Refresh, all you would have left is a controller, charger and 1 extra set of props. Oh, and a nice box
Unfortunately those types of insurances are not available here.
Where are you located? If you arent able to get total loss insurance, I would curtail being overly adventurous and fly to places you would be able to retrieve your drone if it goes down. Did you buy DJI Refresh? If not, you might still be able to buy it. If your drone has exceeded the 48 hour window after you registered it, you can buy Refresh here:
DJI_Care Customer Upload Information
I was there couple months ago. The place is so windy 24/7. I wouldn't risk it flying for more than one mile.I am in the Turks & Caicos Islands. To send and get back any items under warranty (if we get warranty) is more painful than just getting a new item
