Battery Settings for Critically Low and Low Battery Warnings!
vinhidalgo
Hello guys.
I use to fly my MP until I get aprox 45% battery charge. That's why I use 4 batteries most of the times. I've never been in a situation with a Critically Low Battery in real flight, but I've been testing in the backyard how it works. so, what could be a correct setting for Critically Low Battery and Low Battery Warnings?
thanks
Reactions: geoffc
I've read that it's not wise to exhaust the batteries too much, so I set low battery warning to 40 % knowing that I have enough power left, but I land with approximately 35%. So I hope that's a good way to prolong the battery's lifespan. I also have 4 batteries for good flight time all in all.
I think default is 25% I fly to 20% with enough juice to return to home.
In 8% the mavic automaticly dec
And force you to look for landing spot
Cant stand the mayhem caused by the remote when alerting - so in my case I'm sticking with 20% and 10%. I've made it a habit to constantly keep an eye out the battery level. Rarely land with less than 25-30%. Have never been alerted, and I have no plan to be before they give me an option to remove the battle-alarm and use for example vibration.
Marius.
Reactions: Norval
The Mavic controller displays remaining "Usable" power left in the battery . It is an intelligent battery so the logic will not let it discharge to a dangerous low level like you can with regular lipo batteries . I set my 1st warning at 50% just so I get a notice at the halfway point to allow me to check wind , how far away I am etc at that point . My critical warning is set to 10% .
Sure, but that doesn't mean that it will have enough power to get back to where you are instead of landing in dense jungle. The purpose of the alarm is get a notification that will help ensure the drone isn't lost due to running out of battery, not to protect the battery.
Reactions: Norval
Also the slider bar at the top which shows the home point and flight time remaining are a good indicator and normally cut in before you need the low battery warnings. mine are at 30 and 20.
My low warning is set at 30% I usually have it on the ground by then or really close by. Very comfortable that way.
sharpinjr
