Beeping Controller issue
United Kingdom
Hey all,
Was out flying my mini 3 Pro earlier today and all was fine until It wasn't!
My controller seems to have had a meltdown and is beeping now I've tried calibrating and resetting the controller but having no luck.
Also wheb trying to search for firmware updates I get an error message.
Has anyone else come across this?
Hey all,
I would try the firmware update again later - errors like that are not uncommon and usually clear themselves up relatively quickly.
Hi Thanks for the reply. i tried the firmware again and it updated but didn't resolve the issue. i have also just noticed that when trying to complete the compass calibration it just skips straight to "done" without any movement input.
Now that your RC FW updated successfully, recalibrate your sticks and wheels again, after that's done try your compass calibration.
Reactions: RadioFlyerMan
Hi 3rd, i have done those that you have mentioned and still have the same issue, I have been troubleshooting & searching the web for nearly 3 hours now and found nothing. the only thing i did find was someone had the same issue and filmed the controller making the noise but then no comments on a fix for it so was pretty useless.
Firmware updates should not be considered a cure all. They do make adjustments to the programmed information in the device being updated, but seldom repair given issues.
Just to confirm? Did you recalibrate again AFTER your FW update?
Just curious. Did you try to rebind your controller to the drone?
Before you turn on the controller, move both sticks up, down, left and right. The beeping usually occurs when the sticks have been moved during storage and will eventually clear but it's still annoying. After you move the sticks, turn on the controller and that SHOULD fix the beeping issue.
Hi Mark, yes this was also tried multiple times but still no luck. the person who had the same issue on youtube replied to me in the end and DJI replaced the controller but didn't state what the issue was.
I managed to return the drone to the retailer this morning who replaced both the drone & controller so all should be all good now hopefully.
Thanks everyone for the replies, its much appreciated.
Reactions: mereflyer
Espletico
