When I manually start flight the controller indicates home Pointset check map
. But when you do auto launch you can also check the box that says precise home point and the .Mavic I takes off and hovers at approximately 20 feet. While it’s hovering is it establishing a new home point? Which method is the most precise for setting a return to home point. I know You can also manually established return to home point also, so while it’s hovering from auto launch should you reset your home point?
