My New
DJI Mini 2 Fly More Combo has Landed!
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
mavicpilots.com
Even in Pascagoula, there are a couple of Legal Things you may need to do…
So, I guess you have already acquired your TRUST Certificate. If Not, you can get that at the Pilot Institute Web Site (FREE…) . You know your drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my
Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
faadronezone.faa.gov
Since you live in Mississippi, there are specific laws and rules for you to follow, please check to ensure these are current.
Drones are allowed in Mississippi for recreational and commercial use, subject to FAA and local regulations. Read on for details.
drone-laws.com
Even you fly other Drones, it's never a bad thing to listen to some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
Learn and download
DJI Mini 2 related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy, Safe and Legal Droning…
