Big hello from West Midlands, UK
JMSBYD
Stourbridge, West Midlands, UK
Hi all!
Recently bought a 2nd hand Air 2s to dip my toes into the drone world, and am really enjoying it so far.
I have registered my drone and done the A1 certification, though holding off doing the A2 as, from what I can gather, it seems the regulations may be changing in the new year!
Look forward to getting out there and capturing and sharing nature's beauty!
Welcome to the forum! :)
What is your experience in flying birds with a remote?
Rod ..
Actually zero, if I am honest.
Would have loved to fly RC planes as a kid now I look back on it, but I don't know why I never really considered it.. think I was too into music at the time!
Fast-forward to now and I am knee deep in photography and cinematography. I have watched a good friend fly drones for over a decade now, and I think in the beginning they seemed exciting but maybe a bit limited (and expensive).
So far I have taken it to the Wales and flown it on some private land. Guessing I probably not got enough flight time to do the A2 yet anyway.
Though I did get permission from neighbours yesterday to do a little survey of our roof, thankfully they were more intrigued than anything.
Reactions: LoudThunder
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current. You seem to have done all that is required, but here is the link just in case…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Air 2S, including the User Manual.
Fly On and Fly Safe…
Thank you, that is most helpful and very much appreciated!
Yeah the law surrounding them is what I would say I am probably struggling to wrap my head around the most.. plus the fact it seems to be ever-changing doesn't help either. But I think the more I read about it, the more it should sink in.
Though I may have to purchase a sub250g at some point in the future, as I wouldn't mind doing some surveying work and real-estate also.
And yeah 1000% need to go through the manual, for sure.
Hi all!
Welcome to the forum from Len in South Wales , hope you enjoy, cheers Len
osje
