- Joined
- Jul 1, 2017
- Messages
- 157
- Reactions
- 90
- Age
- 60
I was just looking at your DAT file and there was something wrong with the right front motor, it had less rpm than the others.i had only one when my drone droped from the sky
mavic mini crashed without a reason
Hello, my MM has died today...why? I don't know, it was in the air at aprox 70 meters alt and one time the motors stopped and fall down rapidly here is the log and here the video. I bought it last week, this is the second flight and died, i don't know what to do, plase all of you, take a look at...mavicpilots.com
I'm starting to get a bad feeling about the MM.Apparently, the MM's are having all sorts of propulsion and IMU issues. Not sure a firmware change would fix what is seemingly going on with all the noted issues. Granted, they are relatively new, but there are too many issues to notate at present.
I have sent him a message about finding the DAT files on my Ipad only a few minutes ago.yes indeed, i am not an expert, but sar104 is one, and he told me everything that i needed to know
Yes it looks like it was just after autoland.when it gave you the error? when you stopped the motors?
You can't depend on that being the issue. The ESC and other factors are also involved. It is rare that the motor RPM's are the same on all 4, as they should not be.I was just looking at your DAT file and there was something wrong with the right front motor, it had less rpm than the others.
strange....did you say it was on previous firmware, that one with many errors "not enough force" right?
and may i ask what it was you landed on ,the surface i am referring to,Yes it looks like it was just after autoland.
Astro turf.and may i ask what it was you landed on ,the surface i am referring to,
well if the blocked motor warning came up just as you landed it was probably from the motor being stopped because one of the rear blades made contact with the turfAstro turf.
Just had the same problem with my mini. It only flew 3 ft fell to the ground.Tonight I was having a quick look at my flight logs on Airdata.com and noticed that a couple of my flights had "Blocked Motor" error messages.
Please could others also check their logs and report back if you found any of these errors.
