broken front leg.
thanks. iv bought the replacement. could you tell me is it easy to replace???????
regards.
It's not hard at all.. The only tricky part is the pivot.. You will have to apply light pressure to seat it properly while applying enough force to twist the spring.. (you will understand once you take it apart) If you have any mechanical ability its easy.. (I have done 5+ now and I am new to Mavics) You will also need to be careful when re-soldering the wires, but again not hard at all if you can solder to some degree. IF, you have ZERO soldering skills and do not possess the proper tools send it off to Thunderdrones! Using a crappy iron can lift a trace on the ESC board... bad math!
sscott062
