Broken Mavic Pro Screw Hole Fixable??
paulcool
Montreal, Canada
I crashed my mavic and broke the plastic that holds the screw for the left rear arm. I wanted to know any ideas on how to fix this WITHOUT replacing the middle frame completely. Any ideas on how to do this?
New to this, thank you!
it is in a very difficult place to repair,as the arm has to rotate in its housing so it would not have much area to get any sort of epoxy type repair to bond strongly enough and if it came loose during flight then things could go south pretty quick
Not a good spot for a repair.
I think your next move will be shopping and digging into the piggy bank.
Hope you get it done.
Having DIY replaced a front and rear arm on my M2. Unfortunately no way in (insert hot place here). The parts are stressed normally, and there is the likelihood of damage to the internal pivot bushing too (relatively inexpensive to replace but a tear down is in order). If you do a kluged repair and it later fails in flight, you will not be happy.
Jarrcor
