Cable connection from Mavic2 pro to CrystalSky and without wi-fi
Remove the short standard micro-USB cable on the left side on the controller.
Use a USB-A to USB-C cable (yes, you can use the flat one that comes with the M2P) and connect it to the USB-A port on the controller and to the USB-C port in the bottom of the CrystalSky.
No wifi is needed for the connection. You can disable the wifi on the CrystalSky when you fly to minimize the risk for interference.
Thanks for the cable information, that works and I'm ready to fly, wish me luck. Also thanks for the good tip on cancelling wi-fi from cs. ‼
Reactions: Bobvt and droidekas
TPS
