- Joined
- Jan 6, 2018
- Messages
- 4
- Reactions
- 3
- Age
- 44
Which side do you use, USB on the bottom or the side input of the Mavic controller?
Also does it make any difference with signal range?
Either will work, but I like to use the bottom port since it's easier to insert the cable. It's also easier to find regular USB cables if you're in need of a longer cable.Which side do you use, USB on the bottom or the side input of the Mavic controller?
No.does it make any difference with signal range?
