Hi!
My gimbal was stuck and none of the fixes worked (was flying perfectly though). I noticed one of the strands on the transmission cable was broken so I replaced it myself. Did a clean job and there were no issues. When I turned the drone on, there were a plethora of errors starting from camera malfunction, downward sensor error to incompatible gimbal.. and the drone wouldn’t fly (no picture/video feed).
Went through the whole process again and made sure all the connections were ok. Turned it on and the same thing. Thought maybe the replacement cable was faulty so I reinstalled the broken cable to test it but ended up with the same errors.
Tried DJI Assistant: upgraded and downgraded firmware to no avail.
Tried Python calibration but no luck
Attaching image of the errors for reference.
I have been going crazy trying to sort it since I need my drone for work and would really appreciate some help!
I have seen other posts here, and also on DJI forums, where people have reported this problem but couldn’t find a fix.
helppppp
and.. thank you in advance!!!
helppppp
