Are the other features of the controller screen working properly? Is it only the camera view that's not showing?My camera was working perfectly. Took my drone out today and no image on iPhone screen. No crashes, damage etc. What could be a remedy?
Have you tried different cables? The cable needs to be a data cable, not just a charging cable. If it is the cable that came with the drone, it is possible the cable went bad too. It may be time to replace the cable, and if it is make sure it is a data cable which most iPhone cables I believe are.My camera was working perfectly. Took my drone out today and no image on iPhone screen. No crashes, damage etc. What could be a remedy?
You need to supply more information. What device won't display what? Computer? Flight controller with screen? Are you trying to view photographs, flight data, ...? What software are you using?Done a short flight and the data is on the card but will not display the image Please help… TIA
