Can 360 Panos be based on fixed Manual Exposure and Colour Balance?
Bussty
New Zealand (Queenstown)
Site
andrewbusst.wixsite.com
So when taking Panos with my Mini 1 I use Litchi and that just acts as a mover of the drone and gimbal and takes images at whatever exposure settings and white balance I have set on the drone. I always use manual or even AEB in manual mode if an extreme lighting situation
Is that the same with the 360 Pano Mode on the Mini 3 pro?
If it isn't and in that mode it automatically changes exposure and white balance that will make it very tricky to stitch certain scenes. So solution to that is get DJI to add ability to lock down exposure and white balance at the start of a 360 Pano (or any pano). If DJI doesn't then I guess you could wait for Litchi to be available once an SDK is released BUT that would then only work if you purchased the standard controller as you can't load apps to the DJI RC controller with screen (yet). 360 Panos is a key use of my drone photography so any insights here greatly appreciated...
Cheers
Bussty
tagir
