Can anybody Identify This Mavic found in Miami Pawnshop
Stingrayls7
Orlando, FL
Found this in a Miami Pawnshop, it has DJI Mainboard, fullsize controller, and uses a phantom battery. It has a phantom model number and works on First version of DJI Pro.
Reactions: Romulus Archibald
it is not a mavic actually ,its a phantom clone it uses phantom motors and innards and controller ,and was supplied as a kit ,the idea was you dismantled your phantom and then built everything into the new shell and it was meant to mimic the mavics ease of transport as it folded like a mavic
Thanks for the info OMM, I got it for 200 cause they were trying to connect with dji 4 and thought it was broke. I have both versions and when connected it identified as a phantom, cant fly it as im in downtown miami, camera and gimble work fine, still havent found microSD port yet.
Reactions: old man mavic
i believe the SD card slot was on the camera - gimbal mount or it could have a hard to find slot at some point on the outer case very hard to see with the carbon wrap maybe its hidden under the wrap at some point have you looked in the battery compartment
Not a mavic, but apparently someone made a completely custom shell and put P3P innards in it.
There was a project posted on PhantomPilots where a guy was going to make a foldable shell for the P3, but I didn't think it was ever completed.
P3A/P had the SD slot on the gimbal body. There's also a status LED on it, in case that's also covered up, as well as a micro-USB port.
it was made when the first generation Mavic came into being and they were available in a kit form they are actually bigger than the mavic itself to enable the original main board to fit and came with modified wiring and extended cables so that the parts could be connected up ,it was a project that started as a bit of fun just to see if it could be done i watched a video on the exchange process several years ago
Reactions: THE CYBORG
@Meta4 just had a look and yes thats what i was on about ,something to do in the winter months when its not good flying weather ,plenty of old phantoms out there im sure
RobertCNewman
