In either case, the iPad mini seems almost made for this controller.
MA2 317" data-source="post: 1253490" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">I use the same adapter and it works very good.Hello from the Crossroads of America Bmur.
I used to use a mini4 before I purchased a Tripltek tablet.
I was starting to get a CPU overload type of message after a recent update of the Fly App.
I had no performance issues with it and it worked fine, just wanted a brighter screen.
An ipad mini 3 or earlier model may struggle with the App. ?
This is the adapter I purchased when I used the mini4 with my MA2.
Welcome to the Forum. ?
Should be able to, unless an old model no longer supported by DJI.Can I use a Ipad mini to a Mavic Air 2?
Yes, the only problem you may have is seeing the screen in bright sun...Why I plan on using Tripltek
This is the cable from the Tripltek to the air 2 controler??I have both styles holders for my mini 4 tablet. Prefer the wraparound style for stability but takes a few seconds longer to install and blocks the sticks. Doesn't bother me. Needs a little longer cable for either. USB-C to iOS from Amazon
