Car charging problem
MAVICK1
Hi everyone, my car charger is not working, when it is supposedly charging the battery the green light it has starts to blink and I understand that it should stay solid, any help please.
Is your car running? I've read on this forum that your battery needs to be outputting something like 13.2V in order for the charger to work.
Correct, the car needs to be running to supply a minimum of 13VDC, and with the engine off it only supplies 12.4 or so.
Used the hub/car charger to charge a battery with the car off. It stopped charging the after about 15mins, but I had the radio running and after I ran the car for a few minutes, I was able to charge the battery with car and radio off.
Sent from my iPhone using Tapatalk
maybe you can try other 12v outlet. At least, in my car, there are 4 12v outlets with different max amp. each one. When i tried high current chargers, i realized that only in 2 of them they work properly.
Reactions: frogracer
Hi
I have the same problem with my Dji car charger . Have you fixed yours please ?
KenBrackin
