Case and New Gimble Protector
rexster1505
Texas
Couple of days ago this case came in from PGYTECH. It's small enough for a good carryon, yet is pretty spacious inside as the layout is very good. It comes cut for the stock DJI controller and also the RC Pro controller. 3 battery slots, but can hold another battery under the controller. It's also cut in a way that I can put the RC Pro face down with the sticks mounted. I have a piece of closed cell foam between the battery and controller
Reactions: PalmettoAerial
Did the gimble protector come with it? Is it easier to put on than the original one that came with the A2s?
Thank you now I know where to put this thread 🤨
Reactions: old man mavic
No, it just happened to be delivered at the same time as the case..Far easier to me than the DJI one. It's a straight push on and a tight fit
Same one I have. Works great, just don't press it on too hard
Is it a semi rigid case? Better than the stock?
Thanks!
I guess the disconnect has been (at least on my end) has been vendors using the term smart controller. I have found quite a few cases that I thought would be a good fit for my travel needs but have been sitting in the sidelines waiting on a case with foam suited for the RC pro.
Assuming you do have this case and have tested the RC pro’s compatibility
thank you! Ordered today.
Ditto... Thanks CorralesDan for the tip. Been looking for a better gimbal protector for some time. Wish they made one similar for the M2P.
Thanks!
Well, that's my picture and containing the RC Pro. I put it in upside down as that way I don't have to remove the sticks
I got tired of covering the Gimbal and after hearing how many have damaged them by running into objects, I installed this one.
I have looked at their cases before. Didn’t realize they had released these hard cases for the 2S.
Would you have any insight to the differences in the two below? They look identical. One is $119 and one is $99
SKU: P-16A-037
SKU: P-16B-077
Tanvir1798
