Figured it out. Cant set it in manual mode.Im trying to change anti flicker from 50 Hz to 60 Hz and when i touch screen no luck. Any advice. Thank You
thanks for the repsonse G284l. Right I know about the 2;1 ratio. but it was about setting the HZ.. i figured it out that you cant change it in manual mode.Just try a filter to bring shutter speed down, no flicker shutter should be twice the frame per second for example 60 per second shutter should be 120 sec of a second
I've the exact same issue!! The anti flicker setting is greyed out and cannot change it! Help!!!Im trying to change anti flicker from 50 Hz to 60 Hz and when i touch screen no luck. Any advice. Thank You
