Charger and PLUS Battery
They are the same size physically, only the capacity is different. You can mix & match the batteries in the hub no problems.
Reactions: gcopter1
the only difference is the time it takes to charge ,and just to clarify the hub itself is not actually the charger, thats the part that plugs into the power outlet,and then into the hub
Reactions: gcopter1
Rami
