Recommendations for cheap tablet 7" < $150 for Mavic. I have read several discussions, I was wondering if there is a new cheap tablet. I am looking for updates in this topic.
+1 For an Nvidia Shield....
Unless you want something that fits directly into the Mavic RC .... the Shield will only fit into the RC if you make some small changes otherwise you need to use a tablet mount ( there are lots of these ) or the S clips which I liked better than the tablet holders.
I tried a Samsung Galaxy Tab 4 and the video was at best laggy and at worse choppy and broken. .
Sounds like a reception problem with the remote. I haven't seen a Tab 4 do that.
But its true a 150.00 tab 4 7" might be different then a 400.00 ipad mini cellular. And the cellular would be needed to get GPS for some features in the Go app. The Android tablet would have GPS with the wifi version.
Where can I order a set of s or Z clips for NVIDIA Shield???
Nvidia has GPS build-in? I guess that without GPS you can not used the RTH function from Mavic? For example, I have read that you need wifi and celular in ipad mini for use RTH function. Sorry if my questions are to basic I am still learning these stuff
On one occasion there was no video even though it showed it was connected. I unplugged it from the controller and back in and the video appeared.
Forum member @BDOG makes the Z mountsWhere can I order a set of s or Z clips for NVIDIA Shield???
Not all true. RTH will function as it will use the GPS of where the Mavic took off. But if you move (say a boat or walking or what ever) you can not update to a new RTH point. So basically once a Home Point it set (take off) you can not update it unless you come back land and take off again. If you wanted to use a follow me based not on an object (it can loose or get confused on which object it's following) but the GPS remote you would also need GPS in the controller/ tablet.
Having internet is not a bad thing on the tablet also. If your in an area that you want to fly but might be near an airport or no flyzone you have to authorize it to take off. That is done only online. If your out you might not have wifi near by (I use phone tethering so I don't have to pay extra per month). But it is nice to have internet on the tablet. I also upload (healthydrones.com) log info and such on the fly with the internet (but that can be done when you get home or back to wifi).
So I would say GPS not required but best to get something with it (yes Nvidia has it, and most decent andriod does in the middle and upper tier, maybe 50.00 ones don't. iPad need to have cellular version which is like 100.00 extra).
Internet not needed but will make it easier for maps and other things on the fly. And internet maybe wifi for you or cellular if you can afford or have the use to pay per month.
Taken from here:I have a Nvidia Shield table k1 but i use my note 4 for my mavic, my k1 i use inspire 1 i heard that having the go app and the go 4 app on the same android tablet or phone can cause issues . If i install Litchi will it work better for both aircraft inspire 1 and mavic ?
I use the Nvidia Shield and I used to use DJI GO4 without issue. I do use Litchi now though.
