Checking in from CA with a used Mavic 2 zoom
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Thank you. I am a true newbie and am just sitting in my office figuring out how to turn things on and off. I have a smart controller and there doesn't seem to be a lot of basic startup info????? I live 1.5 miles from an airport and want to fly in my backyard to get started but drone says no???
Looks like your in a No Fly Zone being so close to that airport.
As a New Drone Pilot, you need to read up and watch YouTube Videos on DJI's Fly Safe and Geo Fencing to find out where you can fly your new bird.
Apps that will help are B4UFLY, Aloft, AirMap, and UAV Forecast, and there are a couple of Legal Things you will need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic 2 Pro/Zoom, including the User Manual.
Happy Droning…
It does not. Just sits there smirking at me
Get out aways from the airport and it will smile at you.
Be sure and read the links in post # 8 👍
Can I over ride and stay below my tree line?
No, it shouldn’t even spin up in a nfz.
As DirkClodhas advised you, it's not a good idea. Sacramento is a very busy airspace and this weekend there are two very important No Fly Zones due to an airshow and some activities at Beale AFB… it's could bring a knock at your door and it will not be the "Welcome Wagon…"
These NFZ are the type known as a NOTAM No Fly Zone, issued by the FAA, that could get you real trouble, like a large fine at the very least if you violate them.
I live within 4-miles of an Air Force Base and even though I have FAA Authorization to fly in various areas, and I call the Air Traffic Control Facility before flying my Mini 2 Drone, I often get visits at my flying site by various authorities (Military Security Forces and local Police). Oh they know me and they usually just stop by to say hi and see what I'm doing, they sometimes stop by when I forgot or didn't bother to call and when I asked how they knew I was flying, they told me they have the equipment to pick up the telemetry coming from my controller and my drone…
InchWorker
