mavicpilots.com
You've received a lot of good solid advice on what is necessary to fly a drone legally, and I'm going to post it again as it is important.
You wrote, "I'm looking to get a drone for landscape and automotive photography" If these photos or videos are for more than fun, more than for your own enjoyment, you are required to get a Part 107 License to commercialize any products from your drone operations. If they are only to be posted on YouTube and your channel is monetized as in you receive some money for the views, you need a Part 107…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. But the
M3 Classic is heavier and that one is required to be registered whether you are flying for fun or profit.
When I first started flying I registered my
Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
faadronezone.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.
pilotinstitute.com
Since you live in Colorado, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Since you are interested in both the
Mini 3 Pro and the
mavic 3 Classic, I've posted the links to all of the downloads offered by DJI for the
Mini 3 Pro and the
M3 Classic, including the User Manuals.
After you read the Manuals, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Learn and download DJI
Mini 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Mavic 3 Classic related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
