Checking in from New Mexico
Captain Spock
Placitas, New Mexico, USA
Checking in: New Mini2 pilot in NM and having a blast. Great beginner product. I am looking for a cable to attach the controller to my iPhone that has a straight-in plug instead of one with the 90 degree bend in it. The 90 degree will not plug into my iPhone unless I cut my IPhone case to allow it to seat. Appreciate any recommendations.
Greetings from Birmingham Alabama USA, welcome to the forum!
You may need to purchase a cable that is straight instead of angled.
However, the angled cable works with my iPhone case. So must be just the way the case is made
Welcome! I'll be in Albuquerque tomorrow. Going to the Balloon Fiesta (Obviously w/out my Air2S.) My mom's boyfriend Ed Goldstein lived in a geodesic dome home in Placitas many years ago. I believe he passed away many years ago. His son might still live there, not sure.
I've always had good luck with Anker cables. This one should work:
https://www.amazon.com/Lightning-An...ifQ==&sprefix=anker+light,aps,200&sr=8-3&th=1 Before I got my RC Pro, I switched the DJI 90 degree cable for a short Anker USBC to USBC and it worked fine. I have a Note 8 but the lightning to USBC cable should work the same.
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
https://www.amazon.com/Lightning-Anker-Charging-Certified-Supports/dp/B09H6KPRS9/ref=sr_1_3?crid=21XXSMB6HS6KV&keywords=anker+lightning+cable+usb+c&qid=1664467360&qu=eyJxc2MiOiIzLjg5IiwicXNhIjoiMy41OSIsInFzcCI6IjMuMzUifQ==&sprefix=anker+light,aps,200&sr=8-3&th=1 Before I got my RC Pro, I switched the DJI 90 degree cable for a short Anker USBC to USBC and it worked fine. I have a Note 8 but the lightning to USBC cable should work the same.
rawman001: Just what I needed and in various lengths too! I am thinking about trying the my iPad so a longer cable will be needed (along with the expanded holder, etc). We won't be in town for the Balloon Fiesta this year. If you haven't attended previously . . . well . . . it is VERY cool to see 600 balloons launch for the grand ascension. Expect a very early morning run to the Balloon Fiesta Park. Have fun!
Wow, that must be a fun experience to take in. Hope you can get plenty of pictures.
First Fiesta was in 1973! Love it. Last year had an RV spot, that was a lot of fun!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in New Mexico, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy Droning…
Welcome from Cambridge, UK. Have you flown your drone over Area 51 yet?
GLobus55
