Checking In
Welcome to the forum @Wing5! :)
Which drone are you planning on buying?
Buying them all? You're going to have quite the fleet!
Will these be your first DJI drones?
About to spend $ on this Black Friday on new/used Drones and Accessories
Once you get a Drone, you will be a New Drone Pilot, and there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). If your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. If your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Reactions: Hauptmann
Dandoloriom
