Cleaning controller port.
Bunraku
Hi
Just had a disconnect. Although there can be many causes, one of the things to look for could be dirty controller port's.
What's the best way to clean these?
Thanks
The Micro USB port is more flimsy and more prone to damage and dirt than the USB port on the bottom of the controller. I only use the micro USB for charging the battery.
As @Qoncussion said, you can use contact cleaner and maybe a Qtip to get into the smaller port.
Reactions: Bunraku
I use a can of compressed air to clean my remote controller ports. The cans that include the plastic tube extension are best for getting into those small areas. You can find them in your local office supply store or here on Amazon.
Once you get those ports cleaned out, you can keep them clean by plugging the holes with a Micro USB port cover or USB port cover.
Reactions: Bunraku
altinbevera
