Will this work with the smart controller?Open the Google Maps app, press on the top right icon that has your initial, then press offline maps, then select your own map. You can then download the map and have it stored in your device to use without a data connection.
This has no relevance to the OP’s question, the DJI Fly app doesn’t use Google maps.Open the Google Maps app, press on the top right icon that has your initial, then press offline maps, then select your own map. You can then download the map and have it stored in your device to use without a data connection.
Which maps is it using?This has no relevance to the OP’s question, the DJI Fly app doesn’t use Google maps.
Is that also true for iOS? The link only mentions Android.
I believe it is Apple Maps on iOSIs that also true for iOS? The link only mentions Android.
