Consistent ERROR trying to use CsvView
Cookedinlh
Sarnia ON Canada
After finally getting though pulling .dat files off the Mavic 2ED ( in some sort of zip format) I was able to EXTRACT a .DAT file using EXTRACTDJI. When I open that file with CsvView I first get an "Invalid header" and 100% CRC Error rate. It seems to go through the whole file and then reports "Can't populate signals" and "Internal Error" . . I've done this with several Mavic 2 files and they all behave the same. Any ideas on how to resolve this would be appreciated.
I'm trying to get to motor RPM data and not sure this is even the right method.
Thanks
Cookedinlh
You might want to try with these parameters enabled if you haven't already.csview.png
Thanks
Cookedinlh
The M2 .DAT files are encrypted and can’t be processed by CsvView/DatCon. But, the tablet .DAT is not encrypted and can be processed. Look here to see how to retrieve the tablet .DAT
I have not tried ALL combinations of those check boxes but will experiment and see thanks
All my .dat files are internal to the Mavic . . or are there some on the Crystal Sky Controllers ??. . I don;'t use a tablet or phone.
Marcos Machado
