Does the mavic mini control settings allow for full customization so we can fly backwards easier?
Yes - you pull the right stick backwards and the aircraft flies backwards.
Is that easy enough?
How?Of course if flies backwards if you do that. But what i meant is to change the settings around hence full customization. So flying forward is where the back will go forward and the cameras coming to you is pressing the stick down. Get it? But thanks for your response. Someone already assisted.
Just keep practicing the way the controls are without changing them and you will eventually master flying backwardsHow?
