Crash and almost fixed. Need Wiring Help
HB_TV
Maryland
I crashed my drone and fixed everything except a problem with two wires. There is a black and white wire that got caught in the screw and when I went to connect the top it tore the two in half. What is the easiest way to connect these wires back? It has them on both the left and right side. I tried a heat shrink wire connector but it is too long. Can I just solder them back together and electrical tape it? If so, what type of wire? Any help would be appreciated. This is the last thing I have to fix. I hope....
Those are motor wires. If it were me, I would replace the entire wiring harness from the motor to the board. I would not attempt any sort of splice and repair. Yes it means more work but you don't want such an important pair of wires failing.
attifko22
