Crashed into tree, now when I turn camera on, it is stuck facing up
Clare_G101
EDIT SOLVED: I just had to recalibrate IMU
When it's off, I can manipulate the gimbal in any which way, and I already tried to calibrate it, and it didn't have any errors, but when the drone is on, it is stuck looking up, and I can't look down or left/right. Thoughts?
No info from the controller?
Does the gimbal do it’s “dance” on startup.
What are you flying?
I have the same problem, except it's stuck facing down when off. When I turn it on it does it's dance, faces forward, and works properly. When I start to fly the camera eventually faces down and dangles a little and won't move. Once I let it hover for a second it'll go back to normal, but if I fly, again faces down and won't work.
I was able to fix it by recalibrating the IMU, have you tried that?
Mine began doing that when I attached ND filters. Don't know if over time that will harm the gimbal.
Yeah I recalibrated it and it says it's fine, and it works fine. It just malfunctions when I start to fly. It'll drop, face down, and it won't move. Once I let it hover in place, it'll go back to normal. It'll repeat every time I move it.
Serhii83
