- Joined
- Jan 9, 2017
- Messages
- 187
- Reactions
- 71
- Age
- 42
Well after a lot of flights my precheck list is now getting longer due to human error.
I forgot to lock the left frot leg fully out and it folded back in after lift off. I was taking some pictures with a camera of my new filters and gimbal housing from the side a bit. The front leg was in the way of the shot and I partially folded it back a bit for the photo. I actually picked up the mavic (photo was taken on a tool box) and moved it out to the ground without a problem or noticing the problem. But 5 secs after lift off the leg folded back and the rear prop came in contact with the front leg causing a loud noise of repeated prop strikes then a sudden stop of the prop and a flip to the ground from around 5ft up where it landed upside down. Besides some road rash and a new prop in the rear the rest checks out fine and has been flown since.
Lesson make sure the legs are locked in the fully outward position before taking off.
Now for your enjoyment.
